SB8200 White Send light
  • August 9, 2023
  • 481 views
I’m seeing comments about white power light and connection light, but is a white send or upload light an issue?  download is blue upload and power are white - no internet
It's normal for the power light: to be white/receive: blue send: white and online: white. It doesn’t affect the function of the modem.
If there is no internet do a “Reset” and connect the modem directly to the computer and check whether able to go online.
Follow the link below for “Internet Connectivity”:
http://arris.force.com/consumers/articles/General_FAQs/SB8200-Troubleshooting-Internet-Connectivity
