SB8200 WiFi
  • September 30, 2022
  • 72 views
I’m not sure if this was posted before but will the SB8200 have WiFi by itself?
Thanks in advance.
Hello DirEnGrey,
Thanks for this question, the SB8200 it’s a wired cable modem so it won’t have any WiFi capabilities. You will need to get a router to get the wireless connection or get a gateway, which is a modem router combo.
Hope this information helps.
Hello DirEnGrey,
Thanks for the information, this works.
