SB8200 will not power-up, no lights. Website will not validate S/N
  • September 3, 2025
  • 130 views
SB8200 will not power-up, no lights.  Website will not validate the S/N to reach tech support.  Confirmed 12v at plug.  Purchased new Jan 2024, so still within warranty.
Try different power outlets and also if possible please do try a different power adapter.
We would recommend performing a factory reset on the device.
Since you were unable to validate the serial number through our website, we’ve reached out to you via private message for further assistance.
  • September 4, 2025
You’d have to contact CS to get help if the S/N isn’t working.
Do you have a different power supply you can try? I’ve seen them put out 12v but not once they’re under load.
  • September 15, 2025
CS contacted and resolved - Thanks all!
