SB8200v2 will not update firmware using Optimum
  • September 16, 2023
  • 345 views
After I installed the modem last weekend the even log shows that the modem will not update the firmware.
I go to the web page on the modem using the 192.168.100.1 address, no issue.
speed has been good, speed test shows 300 to 200mb download.
There is no update firmware link, or check for latest updates?
I noticed the firmware log shows that it is unable to update firmware. The software writers will need to test their code to find out why it shows it is corrupted on the end modem side.
Here is the log snippet of 2 occurrences:
4/9/2023 17:32:15    5    REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=1c:...;CMTS-MAC=00:01….;CM-QOS=1.1;CM-VER=3.1;
14/9/2023 17:32:21    6    SW Download INIT - Via Config file
14/9/2023 17:32:21    4    SW upgrade Failed after download -Incompatible SW file
14/9/2023 17:32:21    4    SW upgrade Failed after download - SW File corruption
15/9/2023 02:51:23    6    SW Download INIT - Via NMS
15/9/2023 02:51:24    4    SW upgrade Failed after download -Incompatible SW file
15/9/2023 02:51:24    4    SW upgrade Failed after download - SW File corruption
15/9/2023 16:19:52    4    DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=1c:….;CMTS-MAC=00:01:…..;CM-QOS=1.1;CM-VER=3.1;
16/9/2023 02:50:38    6    SW Download INIT - Via NMS
16/9/2023 02:50:39    4    SW upgrade Failed after download -Incompatible SW file
16/9/2023 02:50:39    4    SW upgrade Failed after download - SW File corruption
16/9/2023 08:40:38    3    Successful LAN WebGUI login from 74.xxx.xxx.x on 23/09/16 at 8:50 AM.
Please review this issue.
Hello ssman12341
                                The Cable Operators (MSOs) have complete control of what cable modem/gateway hardware they will allow installed and the firmware it uses, this is because they own the coaxial cable that is connected to the ARRIS SB8200, because of that the Firmware updates are pushed by them, and any update needed as well. Any associated firmware updates are automatically deployed by the cable operator. This is not an ARRIS only implementation, but the required implementation of any cable device manufacturer.
                               So about the event log you need to again check this with your Internet service provider to look for the log status and update the modem accordingly cause they have the access to do it remotely.
Hello ssman12341
