Should the RECEIVE led light ideally always be blue or is it normal to sometimes be green? Sometimes it changes to green meaning it’s in DOCSIS 3.0, and stays there until i power cycle the modem. Is this less than ideal? Does this indicate a problem with the coaxial line
Tends to indicate an issue. If you have docsis 3.1 in your area, it should be blue. It only drops to green when the docsis 3.1 goes down and it reverts to docsis 3.0.
Do you have a screen snip of the cable connections page and event logs?
