Slow/intermittent internet connection on Sb8200
  • January 2, 2024
  • 262 views
I have sb8200 with COX in Phoenix, and I have exactly same thing happening, started about 2 month ago and it would drop to 30 mbps every week or so, cox came out checked the line and said it was good.
It's nice to know that Cox (ISP) has checked the cable lines are good, the slow speed that you have been experiencing has been happening for 2 months could you let us know if it is happening when the modem is connected directly to the computer /laptop or router?
If it is a direct connection, then check if the lights on the modem Power/Receive/Send and online are solid or flashing also check the cable signal levels
If it is connected directly to the router then it could be a Wi-Fi issue in this case contact your router provider and change the Wi-Fi channels
Basically slow speed, intermittent connection or no internet access occurs usually out of cable signal level, out of acceptable range and it will be resolved after the power level are adjusted by the service provider. So for this we need to check the cable signal level to confirm what causing this issue to proceed further. Please use the link below to check the cable signal level on the interface.
