I have had the SB8200 for 2 years with 1000Mbps Xfinty internet service. I use the speed test from my Orbi Router which has showed about 930 for the last two years. This week the internet has seemed slower so ran the test and its 310Mbps down 22 up. I have rebooted the modem and router. I have asked Xfinity to ping and restart. I plugged my computer to the back of the modem port 1 but my Mac self assigns the ip to a 169 so can't seem to make that work.
When I use the web app I get the following info for the download
Connection
The status listed show the connection state of the cable modem. They are used by your service provider to evaluate the operation of the cable modem.
| Startup Procedure | ||
| Procedure | Status | Comment |
| Acquire Downstream Channel | 663000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Configuration File | OK | |
| Security | Enabled | BPI+ |
| DOCSIS Network Access Enabled | Allowed | |
| Downstream Bonded Channels | |||||||
| Channel ID | Lock Status | Modulation | Frequency | Power | SNR/MER | Corrected | Uncorrectables |
| 29 | Locked | QAM256 | 663000000 Hz | -17.9 dBmV | 33.2 dB | 716854 | 99372 |
| 13 | Locked | QAM256 | 567000000 Hz | -15.8 dBmV | 35.1 dB | 0 | 0 |
| 14 | Locked | QAM256 | 573000000 Hz | -15.9 dBmV | 33.0 dB | 0 | 0 |
| 15 | Locked | QAM256 | 579000000 Hz | -15.8 dBmV | 34.3 dB | 0 | 0 |
| 16 | Locked | QAM256 | 585000000 Hz | -16.3 dBmV | 34.8 dB | 0 | 0 |
| 17 | Locked | QAM256 | 591000000 Hz | -16.5 dBmV | 34.7 dB | 0 | 0 |
| 18 | Locked | QAM256 | 597000000 Hz | -16.8 dBmV | 34.3 dB | 0 | 0 |
| 19 | Locked | QAM256 | 603000000 Hz | -17.3 dBmV | 34.0 dB | 0 | 0 |
| 20 | Locked | QAM256 | 609000000 Hz | -17.1 dBmV | 34.2 dB | 0 | 0 |
| 21 | Locked | QAM256 | 615000000 Hz | -17.4 dBmV | 34.0 dB | 0 | 0 |
| 22 | Locked | QAM256 | 621000000 Hz | -17.4 dBmV | 33.8 dB | 0 | 0 |
| 23 | Locked | QAM256 | 627000000 Hz | -17.7 dBmV | 33.4 dB | 0 | 0 |
| 24 | Locked | QAM256 | 633000000 Hz | -18.0 dBmV | 32.8 dB | 0 | 0 |
| 25 | Locked | QAM256 | 639000000 Hz | -17.8 dBmV | 33.4 dB | 0 | 0 |
| 26 | Locked | QAM256 | 645000000 Hz | -17.8 dBmV | 33.5 dB | 0 | 0 |
| 27 | Locked | QAM256 | 651000000 Hz | -17.8 dBmV | 33.5 dB | 0 | 0 |
| 28 | Locked | QAM256 | 657000000 Hz | -17.8 dBmV | 33.4 dB | 0 | 0 |
| 30 | Locked | QAM256 | 669000000 Hz | -18.2 dBmV | 33.0 dB | 0 | 0 |
| 31 | Locked | QAM256 | 675000000 Hz | -18.2 dBmV | 32.2 dB | 0 | 0 |
| 32 | Locked | QAM256 | 681000000 Hz | -18.3 dBmV | 32.9 dB | 0 | 0 |
| 33 | Locked | QAM256 | 687000000 Hz | -18.6 dBmV | 32.7 dB | 0 | 0 |
| 34 | Locked | QAM256 | 693000000 Hz | -18.5 dBmV | 32.9 dB | 0 | 0 |
| 35 | Locked | QAM256 | 699000000 Hz | -19.0 dBmV | 32.5 dB | 5 | 0 |
| 36 | Locked | QAM256 | 705000000 Hz | -19.2 dBmV | 32.3 dB | 765 | 23 |
| 37 | Locked | QAM256 | 711000000 Hz | -19.3 dBmV | 32.1 dB | 23 | 0 |
| 38 | Locked | QAM256 | 717000000 Hz | -19.6 dBmV | 31.9 dB | 0 | 0 |
| 39 | Locked | QAM256 | 723000000 Hz | -20.2 dBmV | 31.4 dB | 20 | 0 |
| 40 | Locked | QAM256 | 729000000 Hz | -20.5 dBmV | 30.8 dB | 233 | 0 |
| 41 | Locked | QAM256 | 735000000 Hz | -20.7 dBmV | 30.3 dB | 2493411 | 1470198 |
| 42 | Locked | QAM256 | 741000000 Hz | -21.4 dBmV | 29.6 dB | 5122088 | 368399 |
| 43 | Locked | QAM256 | 747000000 Hz | -21.9 dBmV | 28.6 dB | 9503579 | 3604322 |
| 44 | Locked | QAM256 | 753000000 Hz | -22.6 dBmV | 27.9 dB | 90789509 | 46896127 |
| 159 | Locked | Other | 762000000 Hz | -22.3 dBmV | 22.8 dB | 712234320 | 137073542 |
