Slow speed internet connection on sb8200
  • March 31, 2025
  • 15 replies
  • 437 views
Hey, the modem keeps blinking orange and settings say 100mbps. If I reset it, it will blink green and say 1000mbps for a little while, but then eventually drop again. The cat 6 ethernet is fine. Xfinity says everything is good on their end. The modem is four years old, do you think it's starting to go?
For your reference, here are the cable signal levels provided by your internet service provider.
Cable signal levels are crucial for ensuring a stable and efficient internet connection. Maintaining these signal levels within the acceptable ranges is essential to avoid issues like buffering, high latency, and frequent disconnections
  1. In the Downstream Bonded Channels section, Power levels are supposed to be within the acceptable range of - 15 dBmV to + 15 dBmV for each downstream channel.
  1. In the Downstream Bonded Channels section, identify the Modulation and Power to find verify SNR levels are within the acceptable range for each downstream channel.
Acceptable SNR Levels (dB)
If QAM64SNR should be 23.5 dB or greater.
If QAM256 and DPL( -6 dBmV to +15 dBmV) SNR should be 30 dB or greater.
If QAM256 and DPL(-15 dBmV to -6 dBmV) SNR should be 33 dB or greater.
  1. In the Upstream Bonded Channels section, identify the number of Channels and Type to find verify Upstream Power levels are within the acceptable range for each upstream channel.
Acceptable Upstream Power Levels (dBmV)
Upstream Transmit Power Level
Channel
US Channel Type
Single SC-QAM 45 dBmV to 61 dBmV
Two SC-QAM 45 dBmV to 54 dBmV
Three or more SC-QAM
45 dBmV to 51 dBmV
Upon checking the signal levels, the upstream is not within the acceptable range. Only your internet service provider can adjust these levels. Please contact them to have the cable signal levels adjusted to the acceptable range.
Could you let us know the product’s model number to assist you further?
  • April 1, 2025
Sb8200
  • April 1, 2025
the led light is?
did you try swapping the cable?
What router is it connected to?
Did you try hardwiring a pc into that port to confirm it isn’t an issue with the router?
  • April 1, 2025
Yeah, the light where the ethernet cable is. I actually just got a new cable, cause my cat chewed it up and put a cable protector on this one. Still having an issue. I also disconnected the router. The ethernet cable is 32 feet from the modem, to the pc.
Could you confirm the LED light status on the front panel of the modem?
Since you're experiencing slow internet speeds, could you share the speed plan you have with your ISP?
If the slow speed persists even with a direct Ethernet connection, I recommend checking the cable signal levels to ensure they are within the acceptable range.
  • April 2, 2025
The led light in front has always been blue. I contacted my isp a couple times and they said everything is fine on their end. OK, I'll try out the cable signal. Wifi has been faster. Ethernet would test at 93mbps and wifi would test at 320mbps. This was when I had the 300mbps plan. When downloading games on steam, it would drop to 0mbps sometimes on both wifi and ethernet. I think that's normal for steam, so the pc can catch up on installing.
I recommend checking the cable signal levels. If the signals are not within the acceptable range, please contact your internet service provider to reprovision or reactivate the modem.
  • April 2, 2025
Says the page is unavailable. I think it’s undergoing maintenance.
  • April 4, 2025
Connection
The status listed show the connection state of the cable modem. They are used by your service provider to evaluate the operation of the cable modem.
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 709750000 Hz Locked
Boot State OK Operational
Configuration File OK
Security Enabled BPI+
44 Locked QAM256 709750000 Hz 5.6 dBmV 44.1 dB 0 0
13 Locked QAM256 523750000 Hz 6.1 dBmV 45.3 dB 53 3
14 Locked QAM256 529750000 Hz 5.4 dBmV 44.8 dB 47 29
15 Locked QAM256 535750000 Hz 5.4 dBmV 44.6 dB 26 0
16 Locked QAM256 541750000 Hz 5.6 dBmV 45.0 dB 18 0
17 Locked QAM256 547750000 Hz 5.6 dBmV 44.8 dB 0 0
18 Locked QAM256 553750000 Hz 5.5 dBmV 44.9 dB 0 0
19 Locked QAM256 559750000 Hz 5.5 dBmV 44.7 dB 0 0
20 Locked QAM256 565750000 Hz 5.2 dBmV 44.6 dB 0 0
21 Locked QAM256 571750000 Hz 5.0 dBmV 44.5 dB 0 0
22 Locked QAM256 577750000 Hz 5.0 dBmV 44.5 dB 0 0
23 Locked QAM256 583750000 Hz 5.4 dBmV 44.5 dB 0 0
24 Locked QAM256 589750000 Hz 5.5 dBmV 44.5 dB 0 0
25 Locked QAM256 595750000 Hz 5.5 dBmV 44.5 dB 0 0
26 Locked QAM256 601750000 Hz 5.2 dBmV 44.3 dB 0 0
27 Locked QAM256 607750000 Hz 5.4 dBmV 44.3 dB 0 0
28 Locked QAM256 613750000 Hz 5.2 dBmV 44.4 dB 0 0
29 Locked QAM256 619750000 Hz 5.3 dBmV 44.3 dB 0 0
30 Locked QAM256 625750000 Hz 5.1 dBmV 44.1 dB 0 0
31 Locked QAM256 631750000 Hz 5.1 dBmV 44.1 dB 0 0
32 Locked QAM256 637750000 Hz 5.0 dBmV 44.1 dB 0 0
33 Locked QAM256 643750000 Hz 5.1 dBmV 44.1 dB 0 0
34 Locked QAM256 649750000 Hz 5.6 dBmV 44.4 dB 0 0
35 Locked QAM256 655750000 Hz 5.9 dBmV 44.5 dB 0 0
36 Locked QAM256 661750000 Hz 5.9 dBmV 44.4 dB 882 2850
37 Locked QAM256 667750000 Hz 5.9 dBmV 44.4 dB 211 846
38 Locked QAM256 673750000 Hz 6.0 dBmV 42.9 dB 150 1
39 Locked QAM256 679750000 Hz 6.2 dBmV 44.5 dB 521 2214
40 Locked QAM256 685750000 Hz 6.4 dBmV 44.6 dB 0 0
41 Locked QAM256 691750000 Hz 6.3 dBmV 44.5 dB 0 0
42 Locked QAM256 697750000 Hz 5.9 dBmV 44.3 dB 0 0
43 Locked QAM256 703750000 Hz 5.6 dBmV 44.3 dB 0 0
193 Locked Other 957000000 Hz 1.6 dBmV 39.0 dB 102573147 335779
Channel Channel ID Lock Status US Channel Type Frequency Width Power
1 17 Locked SC-QAM Upstream 16400000 Hz 6400000 Hz 36.0 dBmV
2 18 Locked SC-QAM Upstream 22800000 Hz 6400000 Hz 36.0 dBmV
3 19 Locked SC-QAM Upstream 29200000 Hz 6400000 Hz 36.0 dBmV
4 20 Locked SC-QAM Upstream 35600000 Hz 6400000 Hz 36.0 dBmV
  • April 7, 2025
These readings were taken when the internet was working fine. Should I wait until the speed dips and the modem starts blinking orange?
  • April 8, 2025
Usually you want it when the internet is sketchy. the event logs are better for long term monitoring.
  • April 8, 2025
Ok, thanks. I'll redo the reading again when I get a chance
  • April 10, 2025
Startup Procedure
44 Locked QAM256 709750000 Hz 5.8 dBmV 44.3 dB 0 0
13 Locked QAM256 523750000 Hz 5.8 dBmV 45.1 dB 92 14
14 Locked QAM256 529750000 Hz 6.1 dBmV 45.3 dB 98 102
15 Locked QAM256 535750000 Hz 6.1 dBmV 45.3 dB 36 0
16 Locked QAM256 541750000 Hz 6.0 dBmV 45.3 dB 18 0
17 Locked QAM256 547750000 Hz 5.9 dBmV 45.1 dB 0 0
18 Locked QAM256 553750000 Hz 5.8 dBmV 45.2 dB 0 0
19 Locked QAM256 559750000 Hz 5.8 dBmV 45.0 dB 0 0
20 Locked QAM256 565750000 Hz 5.5 dBmV 44.8 dB 0 0
21 Locked QAM256 571750000 Hz 5.3 dBmV 44.6 dB 0 0
22 Locked QAM256 577750000 Hz 5.4 dBmV 44.7 dB 0 0
23 Locked QAM256 583750000 Hz 5.7 dBmV 44.7 dB 0 0
24 Locked QAM256 589750000 Hz 5.8 dBmV 44.7 dB 0 0
25 Locked QAM256 595750000 Hz 5.8 dBmV 44.7 dB 0 0
26 Locked QAM256 601750000 Hz 5.6 dBmV 44.5 dB 0 0
27 Locked QAM256 607750000 Hz 5.8 dBmV 44.7 dB 0 0
28 Locked QAM256 613750000 Hz 5.6 dBmV 44.5 dB 0 0
29 Locked QAM256 619750000 Hz 5.7 dBmV 44.6 dB 0 0
30 Locked QAM256 625750000 Hz 5.6 dBmV 44.5 dB 0 0
31 Locked QAM256 631750000 Hz 5.6 dBmV 44.4 dB 0 0
32 Locked QAM256 637750000 Hz 5.4 dBmV 44.3 dB 0 0
33 Locked QAM256 643750000 Hz 5.6 dBmV 44.2 dB 0 0
34 Locked QAM256 649750000 Hz 6.1 dBmV 44.6 dB 0 0
35 Locked QAM256 655750000 Hz 6.3 dBmV 44.8 dB 0 0
36 Locked QAM256 661750000 Hz 6.3 dBmV 44.7 dB 882 2850
37 Locked QAM256 667750000 Hz 6.2 dBmV 44.7 dB 211 846
38 Locked QAM256 673750000 Hz 6.4 dBmV 42.2 dB 150 1
39 Locked QAM256 679750000 Hz 6.4 dBmV 44.7 dB 521 2214
40 Locked QAM256 685750000 Hz 6.6 dBmV 44.7 dB 0 0
41 Locked QAM256 691750000 Hz 6.5 dBmV 44.8 dB 0 0
42 Locked QAM256 697750000 Hz 6.2 dBmV 44.5 dB 0 0
43 Locked QAM256 703750000 Hz 5.9 dBmV 44.5 dB 0 0
193 Locked Other 957000000 Hz 2.7 dBmV 39.8 dB 230445255 733594
1 17 Locked SC-QAM Upstream 16400000 Hz 6400000 Hz 35.0 dBmV
2 18 Locked SC-QAM Upstream 22800000 Hz 6400000 Hz 35.0 dBmV
3 19 Locked SC-QAM Upstream 29200000 Hz 6400000 Hz 35.0 dBmV
Channel
US Channel Type
45 dBmV to 51 dBmV
  • April 11, 2025
Ok, thanks for your help.
