slow speed internet on SB8200
  • January 31, 2024
  • 114 views
I just updated from an old SB6121 to an SB8200. The internet is way slower from before. I checked the status page and it looks like all my power ratings are out of the norms. Any way I can correct this?
Your power levels are all over the place and you have a ton of errors. Go back and check all your connections and check for any line issues or kinks in the line. Direct connect the modem to where the coax comes into the home and try it there. If none of that helps, the ISP needs to check the line
  • January 31, 2024
