Slow speed internet on SB8200
  • 4 September 2024
  • 47 views
I have an SB8200 and pay for 1 Gig download from Xfinity.. I get a lot less than that and when I speak with Xfinity they just say its a modem issue with the SB8200. Everything looks fine with the modem. Downstream Bonded Channels are all within range - the Upstream Bonded Channels are a little low but not huge. How do I run a diagnostic test on the SB8200. This is the second SB82000 in 4 years and I don’t want to buy a third if they don’t last much beyond the warranty. Having said that, I don’t trust Xfinity
I am having nothing but trouble as well with Xfinity and Arris. The modem keeps rebooting itself - it even did it in front of the tech and he said - “See? It’s your modem.” BS. I don’t trust Xfinity either. I’ve had Xfinity Internet for 10 days and it’s been a problem every day.
Following…..
Since the upstream power level is not in a range, I would suggest to contact internet service provider to adjust the signals in range or to reprovisioning the modem.
Following…..
Could you help us with the model number to assist you further?
