Surfboard SB8200-RB lights
  • November 29, 2023
  • 216 views
  • 7 replies
Is it possible to turn off the lights on the modem at night?
certain models had that option but I don’t think the SB8200 did.
A little black electric tape does a pretty solid job though
  • 2292 replies
  • November 29, 2023
  • 7 replies
  • November 29, 2023
I had wondered if it was okay to do that but feared it might block some signals. Thanks!
