Trying to Set Up Arris Modem: Next Step Requires SSID for SB8200
  • July 20, 2024
  • 257 views
Instructions say to locate the SSID and Password on the device label. There is no sub no label. How do I complete this step?
SB8200 is a cable modem that does not have built-in Wi-Fi.
To enable Wi-Fi internet access, you need to connect a separate Wi-Fi router to the SB8200 modem.
I need install instructions SB8200 please
  • September 11, 2024
There is an app for installation. I found it to be useless.
I called my cable provider and they got everything (even the wifi) working. It was about thirty minutes. I had to reboot my smart TV and phone as well.
Could you help us with the model number to assist you further on this issue?
