Warranty Claim , power on failure in SB8200
  • March 31, 2025
  • 79 views
My SB8200 will no longer power on but it’s under warranty. How do I file a claim and exchange it for a replacement modem? Thank you.
If the modem is not powered off, please try a different power outlet and power cord.
Have you tried performing a factory reset to check for any changes in the modem’s behavior?
If the problem persists after trying the above-mentioned troubleshooting, I would suggest visiting www.arris.com/consumersupport for further assistance.
