what is the upload speed capability of SB8200 modem
  • August 6, 2024
  • 663 views
I seem to be finding mixed answers to this question.  So i am wondering what is the official upload speed of the Arris SB8200?
SB8200's maximum compatible speed for the upload is 40 Mbps.
100Mbps, which is considered the Nexgen plan.
The Nexgen plan is not compatible with SB8200. Compatible devices for the Nexgen plan are the G54 and S34.
Upload speed of the modem is depends on the internet service provider you are with.
  • August 12, 2024
Thank you.  I understand my ISP provider dictates this speed, but can this SB8200 handle 100Mbps Upload speed if I get it?
And what the difference between “Wired Speed” and “Best Cable Internet Speed”?
Thanks
Best internet speed for SB8200 is 1GB. Wired speed is totally depending on internet service provider.
Could you let me know your internet service provider?
  • August 14, 2024
My ISP provider is Xfinity with a 500mbps download and 100mbps UPLOAD speed (according to what they are telling me), but I can only get 25mbps upload speed when I run my speed tests.  I am using EERO Pro6 mesh system (3 nodes).
