My aris surfboard sbg10 suddenly stopped working, it’s hot to the touch and won’t reboot
Best answer by Anonymous
I saw a YT video in the past and the modem gets hot when the upstream power level is high. I would try removing splitters, disconnect the coax cable and reconnect (tighten by hand), and try moving it to another coax line in your home if possible. Also try factory resetting by pressing the reset pin hole at the back of the SBG10.
When you purchase another modem/router combo device, look Wi-Fi AC2 or Wi-Fi AX.
