Factory reset performed but won’t accept default password- please help
  • September 10, 2025
  • 8 replies
  • 120 views
Needed to do a factory reset and when I try to login with default username and password it says I’ve been locked out due to number of attempts.  Please advise
You might try pushing and holding reset for up to 30 seconds while powered on. I find many people just click it
Thanks but I still get an error when I go to enter old password and then create a new one.  It says unexpected error
it accepted the default password?
its usually either password or the last 8 of the serial number
I tried both “password “ and the serial number and still got the error.  Crazy!
and you’re sure you reset it back to factory. Again, you can’t just click the button. It has to be held.
What device is it?
Yes
Device is arris Sbg10
  • September 11, 2025
Finally able to get in .  Thanks pleman!
