Frequently need to unplug Surfboard SBG10 due to loss of internet
  • November 21, 2025
  • 76 views
Is there a fix for my problem of routinely having to unplug my SBG10? Too often I have loss of internet and affects all 3 laptops at the worst possible times.  Do I need to update something? Change something? Do I need another new router (this one is  less than 2 years old)  Please help!
The event logs displayed in the interface are related to your Internet service, and ARRIS has no control over them. If there is any issue concerning the service, only your Internet Service Provider can resolve it.
If the problem occurs only over Wi-Fi, we recommend changing the Wi-Fi channels to those with less traffic.
Please refer to the link below for detailed steps on how to change Wi-Fi channels.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/SBG10-Changing-the-Wi-Fi-Channel
To help isolate the issue, could you confirm whether the connection drops only over Wi-Fi or if it also occurs on a wired connection?
If it happens on both then we recommend checking the cable signal levels within the gateway. If the signal levels are out of the acceptable range, they can lead to the kind of connectivity issues you're experiencing.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/SBG10-Cable-Signal-Levels
  • November 24, 2025
Thank you for your response.  All three of my laptops operate on wifi exclusively.  I find that removing the power, waiting, turning it back on as a reset solves the problem. The home is quite small; one latptop is right near the modem/router, the other one is about 25 feet and the third one (up in a loft with a half wall) sits also about 20 feet.  All within a close range.  But I’m pretty tired of having to do this so frequently.  This only started being a nuisance as of a couple of months ago.
  • November 24, 2025
Just checked power levels.  All ok.  Checked “events” and there are a large amount of events.
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=(Edited private information);CMTS-MAC=00:90:f0:35:04:00;CM-QOS=1.1;CM-VER=3.0;
11/13/2025 11:17 84000700 5
RCS Partial Service;CM-MAC=(Edited private information);CMTS-MAC=00:90:f0:35:04:00;CM-QOS=1.1;CM-VER=3.0;
11/13/2025 20:50 82000200 3 No Ranging Response received - T3 time-out;CM-MAC=5(Edited private information);CMTS-MAC=00:90:f0:35:04:00;CM-QOS=1.1;CM-VER=3.0;
11/14/2025 18:03 73040100 6 TLV-11 - unrecognized OID;CM-MAC=(Edited private information);CMTS-MAC=00:90:f0:35:04:00;CM-QOS=1.1;CM-VER=3.0;
11/15/2025 9:23 82000200 3 No Ranging Response received - T3 time-out;CM-MAC=(Edited private information);CMTS-MAC=00:90:f0:35:04:00;CM-QOS=1.1;CM-VER=3.0;
11/16/2025 15:19 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=(Edited private information);CMTS-MAC=00:90:f0:35:04:00;CM-QOS=1.1;CM-VER=3.0;
11/16/2025 15:19 84000700 5 RCS Partial Service;CM-MAC=(Edited private information);CMTS-MAC=00:90:f0:35:04:00;CM-QOS=1.1;CM-VER=3.0;
11/16/2025 23:06 82000200 3 No Ranging Response received - T3 time-out;CM-MAC=(Edited private information);CMTS-MAC=00:90:f0:35:04:00;CM-QOS=1.1;CM-VER=3.0;
