No internet connection (Xfinity)! I am using a new SBG10.
  • January 26, 2024
  • 416 views
Yesterday, a technician from Xfinity came to my house for wiring.
He said everything was fine with the line, but no internet connection was found. He said I have to set up something with the SBG10. I followed all the instructions in the manual, but the internet connection failed.
I can see ARRIS-7E05 and ARRIS-7E05-5G in the Wi-Fi list on my laptop. When I connect to them, the internet is not working, and the connection is not established. One strange thing is that if I connect them with my iPhone, I can only access YouTube and Google. When I access Google and click on some other links, I can't see anything. All other websites are not accessible.
What is the problem? Is there something wrong with Xfinity?
I suggest you to factory reset the modem and try with self-activation through Xfinity application.
  • January 26, 2024
Can you stream on youtube?
Did you check to see if the mac address registered is correct with xfinity?
Try a factory reset?
  • January 26, 2024
I did.
I checked all things.
Same problem.
Thanks.
Hope you are able to  connect to the internet, after trying on the Reset and Self-activation through the Xfinity Application.
