password to start it up for SBG10
  • November 27, 2023
  • 186 views
I bought a new SBG10. It wont accept password provided to start it up. What do I do
The password, you are asking about Wi-Fi password or GUI web portal login password.
If you are referring Wi-Fi password, you can locate the default credentials at the bottom of the modem.
GUI web portal login password, you can try password as password to create new password.
  • November 27, 2023
did you try password or the last 8 of the serial number?
