SBG10 port forwarding invalid ip address
  • December 31, 2025
  • 18 views
-Attempting to port forward/open port for purposes of creating a dedicated server to play a PC game with friends
-Inputting physical IP address (acquired from canyouseeme and similar) at XX.XX.XXX.XXX returns invalid IP address
-Inputting ipv4 address obtained from ipconfig check at XXX.XXX.X.X returns invalid ip address
-Inbound port range set for 8211 to 8211
-Local port range same
-Format is UDP
For port forwarding to work efficiently, you must first reserve the IP address of the device you intend to port forward.
Please note that port forwarding is only possible for devices within your network.
Refer to the link below for instructions on how to reserve the IP address of a device connected to your network.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/SBG10-IP-Address-Reserve-Setup
Please use the link below as a reference for instructions on how to set up port forwarding
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/SBG10-Port-Forwarding-Setup
