surfboard Wi-Fi Cable Modem AC1600 Wi-Fi. 5
  • August 9, 2025
  • 58 views
I, have forgotten my Password.  How can I, acquire a new Password, to activate the Surfboard, SBG10 on my new LG 65" Flatscreen??
Thanks
ED. Smalls
Retired.  U.S.A.F
If your phone or computer is already connected to the Wi-Fi, you can check the saved password in the Wi-Fi settings.
You can also perform a factory reset on your gateway. This will restore it to its default settings. After the reset, you’ll find the default Wi-Fi name and password on a label at the bottom of the device, usually listed as the Wi-Fi Security Key.
Once you have the password, you can reconnect your TV or other devices to the Wi-Fi.
  • August 9, 2025
I  forgot my password.  How can I, acquire a new Password to place into the Surfboard????
  • August 9, 2025
I, did enter Text, two separate times.
  • August 9, 2025
Are you playing Games??
