changing to 2.4g from 5
  • July 11, 2024
  • 110 views
How do I change my SBG7600AC2 from 5g to 2.4?
To change devices from 5G to 2.4 you can just select the network on wifi settings but if you want to change the wifi for modem you need to login to the modem GUI and you can disable 5G on the modem interface that will make the 5G network completely Off so you can only use the 2.4 network alone.
