GUI web portal still locked after multiple factory resets SBG7600AC2
  • February 24, 2024
  • 118 views
My username and password was locked and after multiple factory resets and setups the username and password is still locked. The customer support number  doesn’t work either so I’m stuck. I read it’s possible that it could remain locked if I registered my warranty initially. Any assistance would be appreciated.
the new app surfboard central doesn’t help either it won’t connect to my home network and just is stuck there.
Performing reset will definitely take you to the modem setting page using default login credentials. Even you tried multiple reset we would suggest you to try hard reset on the modem for one last time and then try accessing interface using default login credentials.
To perform hard reset disconnect the coaxial cable from the back of the device? At the back of the modem, in the middle section you will see a small hole, inside that hole there is a button, and that is the reset button, please insert a paper clip or a tip of a pen and hold it for 15-30 seconds until all your lights go off, afterwards connect the coax cable back and wait until your device fully boots up.
But after resetting the modem will go to default setup any custom settings will be removed so use the default network name and password
to connect to your network.
http://arris.force.com/consumers/articles/General_FAQs/SBG7600AC2-Web-Manager-Access
