How to turn on AP mode on SBG7600AC2
  • May 24, 2024
  • 348 views
I have Arris sbg7600ac2 and would like to use it for wireless only. How can I turn on AP mode?
Login to the modem GUI or modem web interface and on the interface select wireless 2.4Ghz option on the top menu > AP isolation > you can enable or disable by checking into the box.
Launch a web browser, such as Internet Explorer, Firefox, or Safari.  Enter http://192.168.0.1 into the address box, and press the Enter key.  The Login page will appear.
On the Login page, enter admin in the User Name field.
Enter password or a customized password in the Password field.
Click the Apply button.  The System Basic Setup window will appear.
