intermittent internet connection on sbg7600AC2
  • September 8, 2024
  • 49 views
I'm having same issue  with sbg7600, cut out 4 times yesterday.  Before that it was fine.
Is this issue happening on the modem direct connection or is this on the Wi-Fi connected devices are affected?
If this is on Wi-Fi we would suggest you to change the Wi-Fi channel on the modem GUI.
If the intermittent is also happening on the direct connection then we need to check for the cable signal level to check the issue further.
