For the past week, the wifi has been terrible. Our phones/iPads keep disconnecting. All our smart home devices are fine and any hard-wired/ethernet-connected devices work just fine. Both of the wifi symbols (bottom two) on the device blink constantly. When I check Xfinity it says service/connection is fine. I’ve done multiple hard resets and still no change. The disconnect is random, too. Sometimes when I restart a device it will connect to the wifi, work for a bit, but then cut out. Other times no matter how many times I restart the device, it won’t connect to the wifi (prompts me for wifi password, which it then says is wrong when it isn’t). Any help/advice would be greatly appreciated. Thank you.
Intermittent WiFi Disconnections SBG7600AC2
Since this is happening on wifi we would suggest you to try changing wifi channels will avoid interference and that will give better speed and connection.
If other Wi-Fi sources such as neighboring wireless access points are using the same wireless channel, this may cause intermittent connectivity issues, even if the competing signal is relatively weak. Changing the wireless channel within the gateway can improve connectivity.
After changing wifi channel as recommended on the link restart the modem then we would request you to monitor the connection for next 24hrs.
