Only Power LED light on SBG7600AC2
  • July 23, 2025
  • 87 views
How do I fix my SBG7600AC2 WiFi cable modem?
The power indicator light is on, but no other status lights turn on. No send/receive light, online light, wireless lights, or WPS light. My WiFi network is not being broadcast or not discoverable when I try to connect my devices.
I have unplugged the power cable for 15 seconds, and power cycled the modem, but it still does nothing except show a power light.
I also checked that the coaxial cable is tight against the back of the modem and tight against the cable outlet on the wall.
Please try connecting the gateway to a different power outlet. If the issue persists, we recommend using an alternative power cord. Additionally, you may try performing a factory reset on the gateway. If the problem continues even after that, we suggest checking the Ethernet ports on the gateway to help determine its current condition.
  1. Click on the Apple menu.
