PW
  • January 26, 2026
  • 29 views
I have a Arris OBBD Router that I need to have the PW reset.
Could you please confirm your product’s model number?
  • January 26, 2026
It is an Arris SBG6950AC2
(Edited private information)
  • January 27, 2026
Push and hold the reset button for 7-15 seconds while powered on. that’ll reset it back to factory to where you can reinstall it and set your own password.
If you are referring to changing the Wi-Fi password
You can change the Wi-Fi credentials in two ways:
  1. Through the Surfboard Central mobile app (if you have it set up).
  2. Via the web interface.
Please refer to the link below for instructions on changing Wi-Fi credentials using the Surfboard Central app.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/SURFboard-Central-Changing-the-Wi-Fi-Name-Password
The next link provides guidance on how to update Wi-Fi credentials through the web interface.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/SBG6950AC2-Wi-Fi-Name-and-Password
