I accidentally deactivated 5G which turned off internet. Can't login to enable. Model is SBG7600AC2
reactivate 5g
The SBG7600AC2 is a dual-band Wi-Fi cable modem. If you have disabled the 5GHz network, you can connect your device to the 2.4GHz network to access the interface and re-enable it. Alternatively, you can connect a computer directly to the modem using an Ethernet cable to access the interface as well.
