SBG7400AC2 Internet randomly drops
  • October 30, 2023
  • 14 replies
  • 540 views
I’ve had this device for about a year and 5 months. It did okay until the last couple months or so. Now the internet- both ethernet and wifi- keep dropping at random times. I work from home, so this is obviously not a good thing. I have Spectrum 500Mbps plan. I haven’t contacted Spectrum yet to see if there were any problems with the line, but they were just out here summer of 2022 and didn’t find any issues, except they replaced the cable running to the modem with a new piece that had a 90* angle connector at the wall, and then it worked fine until recently.
@orangejello That prior poster had spam links in their post. Ignore them. bot or spammer.
Your logs are indicating a line issue.
IF that doesn’t help, the isp needs to check the lines.
not saying 100% its not a modem issue, but the logs indicate issues with the line.
  • October 31, 2023
Do wired devices drop to?
got a screensnip of the cable connections page and event logs?
  • October 31, 2023
Yes the wired connections drop too. Internet dropped about once every half hour last night. I looked at the modem while it was happening this time, and every time the signal drops, I catch the modem rebooting itself. Why is that happening?
I just did a factory reset on my device so I can update with logs if/when I have another signal drop or reboot.
  • November 1, 2023
Yes, the wired connection drops too. I watched the modem lights while it dropped yesterday, and every time it did, the modem was rebooting itself, so maybe that’s another clue.
  • November 1, 2023
the event logs and cable connections page helps with that.
Did you contact your isp? If its a line issue, thats a good place to start
  • November 1, 2023
Weirdly enough, I saw two techs from my internet company in my yard looking at the boxes yesterday morning (I didn’t even call them). We didn’t have any outages yesterday or today, so I’m hoping my problem was the line and it’s been fixed.
  • November 1, 2023
Update: Well I jinxed myself. The device just rebooted itself a few minutes ago. I looked at the logs right away and it said “Dropped FORWARD packet” at that time. I didn’t know it was refresh over those logs, so I didn’t copy them in time I guess.
  • November 1, 2023
Wireless logs from this afternoon:
2023-11-01 14:13:30.00 [UNPRIV UDP packet: ]UDP Packet - Source:18.223.127.200,32099 Destination:REDACTED IP,24769
2023-11-01 14:13:30.00 [UNPRIV UDP packet: ]UDP Packet - Source:54.153.101.7,32099 Destination:REDACTED IP,24769
2023-11-01 14:13:30.00 [UNPRIV TCP packet: ]TCP Packet - Source:94.102.61.41,54590 Destination:REDACTED IP,6667
2023-11-01 14:13:40.00 [PRIV TCP packet: ]TCP Packet - Source:86.60.137.203,37460 Destination:REDACTED IP,23
2023-11-01 14:13:45.00 [UNPRIV UDP packet: ]UDP Packet - Source:3.131.209.36,32099 Destination:REDACTED IP,18616
2023-11-01 14:13:47.00 [UNPRIV TCP packet: ]TCP Packet - Source:79.124.62.130,52836 Destination:REDACTED IP,55367
2023-11-01 14:14:03.00 [UNPRIV TCP packet: ]TCP Packet - Source:179.43.183.214,55472 Destination:REDACTED IP,2222
2023-11-01 14:14:06.00 [UNPRIV TCP packet: ]TCP Packet - Source:78.128.113.250,44337 Destination:REDACTED IP,2223
2023-11-01 14:14:13.00 [PRIV TCP packet: ]TCP Packet - Source:71.212.50.38,1255 Destination:REDACTED IP,23
2023-11-01 14:14:18.00 [UNPRIV TCP packet: ]TCP Packet - Source:162.142.125.247,22093 Destination:REDACTED IP,45918
2023-11-01 14:14:27.00 [UNPRIV TCP packet: ]TCP Packet - Source:79.124.62.86,52835 Destination:REDACTED IP,62581
2023-11-01 14:14:32.00 [UNPRIV UDP packet: ]UDP Packet - Source:18.223.127.200,32099 Destination:REDACTED IP,14115
2023-11-01 14:14:32.00 [UNPRIV UDP packet: ]UDP Packet - Source:54.153.101.7,32099 Destination:REDACTED IP,14115
2023-11-01 14:14:35.00 [UNPRIV TCP packet: ]TCP Packet - Source:180.149.125.235,18484 Destination:REDACTED IP,7777
2023-11-01 14:14:43.00 [Dropped FORWARD packet: ]TCP Packet - Source:2600:9000:21fa:3a00:001a:b464:0700:0021,443 Destination:REDACTED,57997
2023-11-01 14:14:43.00 [Dropped FORWARD packet: ]TCP Packet - Source:2600:9000:2043:e400:0018:b771:ac40:0021,443 Destination:REDACTED,57998
2023-11-01 14:14:43.00 [Dropped FORWARD packet: ]TCP Packet - Source:2600:9000:254b:2400:000a:6f99:2300:0021,443 Destination:REDACTED,57999
2023-11-01 14:14:44.00 [UNPRIV TCP packet: ]TCP Packet - Source:198.235.24.208,52745 Destination:REDACTED IP,8085
2023-11-01 14:14:45.00 [UNPRIV UDP packet: ]UDP Packet - Source:3.131.209.36,32099 Destination:REDACTED IP,24647
2023-11-01 14:15:05.00 [UNPRIV TCP packet: ]TCP Packet - Source:77.90.185.122,43377 Destination:REDACTED IP,47777
2023-11-01 14:15:11.00 [UNPRIV TCP packet: ]TCP Packet - Source:183.136.225.9,59406 Destination:REDACTED IP,9001
2023-11-01 14:15:18.00 [UNPRIV TCP packet: ]TCP Packet - Source:77.90.185.167,51082 Destination:REDACTED IP,63602
2023-11-01 14:15:29.00 [UNPRIV TCP packet: ]TCP Packet - Source:62.204.41.200,57544 Destination:REDACTED IP,51160
2023-11-01 14:15:36.00 [UNPRIV UDP packet: ]UDP Packet - Source:18.223.127.200,32099 Destination:REDACTED IP,27045
2023-11-01 14:15:36.00 [UNPRIV UDP packet: ]UDP Packet - Source:54.153.101.7,32099 Destination:REDACTED IP,27045
2023-11-01 14:15:39.00 [UNPRIV TCP packet: ]TCP Packet - Source:79.124.62.130,52836 Destination:REDACTED IP,34696
2023-11-01 14:15:50.00 [UNPRIV TCP packet: ]TCP Packet - Source:77.90.185.72,41508 Destination:REDACTED IP,3376
2023-11-01 14:15:56.00 [UNPRIV TCP packet: ]TCP Packet - Source:77.90.185.150,40629 Destination:REDACTED IP,4444
2023-11-01 14:16:08.00 [UNPRIV TCP packet: ]TCP Packet - Source:194.26.135.109,59288 Destination:REDACTED IP,3331
DOCSIS(CM) Events
Date Time
Event ID
Event Level
Description
10/30/2023 22:00
82000200
3
No Ranging Response received - T3 time-out;CM-MAC=REDACTED MAC;CMTS-MAC=REDACTED;CM-QOS=1.1;CM-VER=3.0;
10/30/2023 22:53
82000400
3
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=REDACTED MAC;CMTS-MAC=REDACTED;CM-QOS=1.1;CM-VER=3.0;
1/1/1970 0:01
82000200
3
10/31/2023 0:13
82000400
3
1/1/1970 0:01
82000200
3
10/31/2023 0:16
82000400
3
10/31/2023 6:31
82000200
3
10/31/2023 14:45
84000700
5
RCS Partial Service;CM-MAC=REDACTED MAC;CMTS-MAC=REDACTED;CM-QOS=1.1;CM-VER=3.0;
1/1/1970 0:01
82000200
3
11/1/2023 1:23
82000300
3
Ranging Request Retries exhausted;CM-MAC=REDACTED MAC;CMTS-MAC=REDACTED;CM-QOS=1.1;CM-VER=3.0;
11/1/2023 1:23
82000600
3
Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=REDACTED MAC;CMTS-MAC=REDACTED;CM-QOS=1.1;CM-VER=3.0;
11/1/2023 1:24
82000200
3
11/1/2023 1:27
82000400
3
1/1/1970 0:01
82000200
3
11/1/2023 12:18
82000400
3
1/1/1970 0:01
82000200
3
11/1/2023 14:11
82000300
3
11/1/2023 14:11
82000600
3
11/1/2023 14:11
82000300
3
11/1/2023 14:11
82000600
3
  • November 2, 2023
The first thing that should be done in any troubleshooting is to power cycle the effected devices. Unplug the SBG7400AC2 from the power, wait 10 seconds, then plug back into power. Once the SBG7400AC2 is full on and the top four LED lights are solid, power cycle all effected client devices.I've had this device for about a year and 5 months. It did okay until the last couple months or so. Now the internet- both ethernet and ...Restarting your modem and router can help refresh the connection and clear any temporary issues that may be causing the problem. Check network cables and connections: Ensure that all network cables and connections are securely plugged in and free from damage
Yes of course, when this first started the first thing I did was reboot the device and check the cable connection was tight. The device seems to be saving me the trouble by rebooting itself over and over again.
  • November 2, 2023
  • November 2, 2023
Thanks. I called my ISP. At first they said they could detect no signal issues, but when I read them the logs, they were like “Yup. That issue is on us.” Someone is coming out next week to look at it and hopefully that resolves it!
  • November 2, 2023
Where did you get the log? Xfinity doesn’t provide them as far as I can see. Neither does Arris.
  • November 2, 2023
I don’t use the app, so this is how I did it. Your mileage may vary... I type modem IP address into my browser, and log in.
At the top of the page are 2 tabs: Wireless (router logs) or HSD (modem logs).
Choose Wireless, then the Utilities tab
Choose System Logs under the Utilities menu to get router logs
Now go back to the HSD tab up top.
Choose Event Log from this menu to get modem logs.
  • November 3, 2023
@orangejello thanks so much! I appreciate you taking the time. My home screen from Arris looks different, but I do have an option to get system or event logs. They claim I have 0 event or system logs for today or yesterday. Who knows! I fear I’ll have to get a new router/modem before long. I can’t get even an hour meeting without it restarting. I’m on hot spots only, and my cell reception isn’t great. I did my own question so perhaps someone will help me there.
Since your modem is rebooting on its own, let us know the product’s model number to access with troubleshooting.
If there is no event log or system logs in GUI web portal, I suggest you to contact your internet service provider for further assistance.
