I am using iptv and tivimate to stream TV. they stoped working and will not let me reload them. I get good internet speed but can not login to these providers. Contacted them and everything is working fine on there end. Before that my speed was slower then amazon tv speed. Reset the modem and fire stick and still nothing.
SBG7400AC2 - Slow speed on Amazon tv
Since you are experiencing issues connecting only with TV, I would suggest changing the security mode on the GUI web portal.
To change the security mode, please launch the web browser and enter the IP address, which is 192.168.0.1.
Login with credentials > System basic setup > Wireless 2.4 GHz > Security mode Change it to WPA/WPA2-PSK (TKIP/AES) recommended.
You can try connecting the TV after changing the security mode. If the same problem persists, I would suggest checking with the TV manufacturer for further assistance.
