SBG7600AC2
  • October 3, 2025
  • 25 views
On one end of my house, the farthest from the modem/router the signal strength is low. Can I use any of the Arris mesh systems with the SBG7600AC2 to improve the signal strength?
As a standalone gateway, it can cover up to 2,200 sq. ft., though actual coverage may vary depending on factors such as the number of floors, concrete walls, and nearby electronic devices like microwave ovens that can cause interference.
To reduce Wi-Fi congestion and improve signal strength, ensure the gateway is placed at a higher elevation in a central, open area of your home.
If your property exceeds 2,200 sq. ft., we recommend using Wi-Fi extenders or a mesh system to ensure consistent coverage throughout the space.
