SBG7600AC2
  • November 21, 2025
  • 71 views
I cant access my gateway access account even though I inputted my correct password. It states “ account locked due to too many attempts”. How can I go about this?
Please advise, thank you.
If you forget the password for the interface login, we recommend performing a factory reset by holding the reset button for at least 20 seconds. This will restore the entire gateway to its factory default settings.
  • November 21, 2025
Usually it locks you out for a period of time. But the problem is, if you dont know the password, you’d need to reset to get back in.
  • November 23, 2025
How do I do that ? Reset the password.
