I am experiencing unstable internet due lights on my modem went off and back after a while.
Answer
SBG7600AC2 all LED LIGHTS TURNS OFF AND ON
Hello olusola09
As you also mentioned co-axial cable and lines connections are fine .
This is a gateway device , which is a combination of modem and router , we need to check the values of downstream power/snr and upstream power values which is the cable signal levels
To check on it follow the link below:
Do screen share the values so, we can understand the issue better .
