SBG7600AC2 WiFi intermittency
  • May 10, 2025
  • 6 replies
  • 87 views
WiFi signal is intermittent. Connections are fine using direct Ethernet. I’ve restarted multiple times and have left it unplugged for 48 hours. Signal is there, but intermittency increases with time. Anything I’m missing?
Therefore, we recommend changing the Wi-Fi channels, as the current ones might be experiencing interference.
Switching to a different channel can reduce interference from other devices and networks, making your connection more stable. A clearer channel can make your Wi-Fi connection more reliable, with fewer dropouts. Moreover, changing to a less crowded channel can enhance the quality of your Wi-Fi signal.
Please refer to the link below for detailed steps on how to change your Wi-Fi channels.
http://arris.force.com/consumers/articles/knowledge/SBG7600AC2-Changing-the-Wi-Fi-Channel
As you mentioned, the Wi-Fi connection dropping suggests that the SBG7600AC2 might be experiencing congestion and high interference. Make sure that the SBG7600AC2 is placed in an open area and at a higher altitude.
Could you please confirm if it is only the internet connection dropping, or if the Wi-Fi network names are disappearing as well?
  • May 11, 2025
Thanks for your reply. I understand what you’re saying about placement and it should be good. Network names are present. States, “Secure, no internet”.
  • May 14, 2025
I’ve done all this before I reached out. I’ve had the cable company ping while it was connecting and when it wasn’t connecting. When connected, all good, when disconnected, cable company say’s my modem is off-line. I’ve check signal strength and anything else Google and ChatGPT have said to try. It all points to bad modem.
If you tried all the possible troubleshooting steps, I would suggest visiting www.arris.com/consumersupport to contact technical support for further assistance.
  • May 22, 2025
I’ve been messing around with it a bit. I tried it again after 2 days of being unpowered and subsequently worked but would get more intermittent as the day went on. Had 2 rounds of that, then on the 3rd round, it’s had no issue after several days (now a week). I guess I’ll count my blessings at this point.
