send/receive light blinking SBG6950AC2
  • June 1, 2023
  • 2109 views
The send receive light is blinking on my device. In the book it says it's does that when it's updating the modem but it's been over an hour now. And it is still blinking. I have power down the device a couple times and nothing has worked.
Hello Clown69,
When the send/receive lights are blinking then it shows that cable signal levels are not on acceptable range .
Follow the link below to check the cable signal levels :
http://arris.force.com/consumers/articles/General_FAQs/SBG6950AC2-Cable-Signal-Levels
Do screen share the downstream channels  highest and lowest power levels and SNR and upstream channels highest and lowest power levels .
  • June 2, 2023
Have you checked with your ISP?
Hello Clown69,
