Slow speed internet when try connecting the modem from 1st floor and modem is on second floor - SBG7400AC2
  • February 19, 2025
  • 50 views
When I run a speed check on my Apple iPhone, I get 279 Mbps on the first floor.  The SBG7400AC2 is on second floor.
When in the room with the modem, I get as high as 650 Mbps.
Can I turn off the Wi-Fi on the modem, maintain the cable input and use another device for Wi-Fi with a device on second floor and another on first floor.  I have an option of the first floor being hard wired if needed.  This is where I use laptop and stream on main TV.
Thanks.
You can. What I’d do through is pickup a mesh system like the w130. You can put the SBG in modem only/bridge mode and then connect the mesh system to it. they can work with a wired backhaul and then give you multiple access points.
  • February 19, 2025
  • February 27, 2025
Thank you for your help.  I will look into this option.
