SBG7600AC2 all LED LIGHTS TURNS OFF AND ON
  • 24 May 2023
  • 49 views
I am experiencing unstable internet due lights on my modem went off and  back after a while.
Best answer by SURFboard Moderator 13 June 2023, 15:21
Userlevel 6
Badge +40
Usually tends to indicate a line issue.
did you check all the coax connections?
Or check with the isp?
I connections are ok. but still i experience this issue at morning time. Thanks
Hello olusola09
As you also mentioned co-axial cable and lines connections are fine .
 This is a gateway device , which is a combination of modem and router , we need to check the values of downstream power/snr and upstream power values which is the cable signal levels
To check on it follow the link below:
Do screen share the values so, we can understand the issue better .
