2.4 Network Not Broadcasting Changed SSID and Password
  • July 3, 2023
  • 75 views
New 8300 User. When I logged in on my iPhone using the default settings for the 2.4 network I had internet. I changed the SSID name/password of that 2.4 band but the gateway is not broadcasting it; it still shows the default. I’ve restarted the app and rebooted the gateway.
I’ve also tried logging into the Web interface but I can’t seem to get in.
Advice please. i have a ton of 2.4 band devices that are wondering why I have deserted them...
Maybe something got messed up while changing it. Have you tried a simple factory reset and reinstall?
  • 2253 replies
  • July 7, 2023
