backup settings for SBG8300
  • February 4, 2024
  • 93 views
I just setup the SBG8300 and now that I have the device configured I was wondering if there was a way to backup the settings just in case ?
Best answer by tvr4
SBG8300 doesn't have the option to Backup and restore, so if your modem went through the factory or resetting process it will go to the default setup all your custom settings will be removed.
 It was worth a try.  I could print the admin screens like I did on the old router.
Not as easy but it works
Thanks for the help
  • February 5, 2024
Thanks for the help
