best extender recommendation for SBG8300
  • June 20, 2024
  • 279 views
Please recommend compatible extender by make and model that is compatible with SBG8300.
SBG8300 are compatible with all brand extenders and to suggest you our Arris product you can try the mesh wifi system or the MAX router to get better wifi signal that cover wider range and also you can add satellite to extend the wifi signal to your home completely. For more information you can check on surfboard.com for the product details and specifications.
