Connectivity issues on SBG8300
  • April 24, 2025
  • 104 views
I have a SBG8300 and am having connectivity issues.  My local internet provider said everything was good on their end suggested I call ARRIS to see if there is a problem with this device.  Can you assist
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • April 24, 2025
Can you be more specific about what kind of errors you are encountering?
  • Have you checked the console for signal strength and SNR?
  • Have you checked the log for errors?
  • Is the problem with the network connection, or with WiFi?
