Dead SBG8300
  • December 19, 2025
  • 45 views
The warrantee on my SBG8300 expired in October, and in November, so did the unit itself (both leds solid blue instantly on power up, no appearent boot sequence, no WiFi signal, no change after pressing reset button). Is it worthwhile to try to get this unit repaired?
Please try different power outlets and also if possible please do try a different power adapter.
If the issue continues, we recommend performing a factory reset on the device.
