Is there a firmware update (yes, I know the ISP, (that refuses to support me, or keep things up to date) pushes it) to enable Ethernet WAN on the DG3450 (SBG8300 has it, and it’s the same thing)
DG3450/TG3452 WAN
Hello appleeimac
There isn’t a way. the firmware is part of the provisioning and is pushed by the ISP. Nothing the end user can update.
Its one of the reasons I usually recommend a modem separate from the router. So you control the firmware and can change routers as needed.
Hello appleeimac
This doesn’t answer my question. Did you ACTAULLY READ what I said instead of just replying with a templated response?
Oh, I do, but MoCA is a part of my Network.
