DG3450/TG3452 WAN
  • August 28, 2023
  • 789 views
Is there a firmware update (yes, I know the ISP, (that refuses to support me, or keep things up to date) pushes it) to enable Ethernet WAN on the DG3450 (SBG8300 has it, and it’s the same thing)
Its one of the reasons I usually recommend a modem separate from the router. So you control the firmware and can change routers as needed.
Hello appleeimac
                               There isn’t a way. the firmware is part of the provisioning and is pushed by the ISP. Nothing the end user can update.
  • August 29, 2023
  • August 31, 2023
Hello appleeimac
This doesn’t answer my question. Did you ACTAULLY READ what I said instead of just replying with a templated response?
  • August 31, 2023
Oh, I do, but MoCA is a part of my Network.
