disabled 2.4g wifi
  • August 16, 2023
  • 77 views
I try to connect to my 2.4 g wifi and it says disabled but when I go into my surfboard it’s enabled and I still can’t connect
Try doing a “Factory Reset” and connect to the 2.4 GHz with default credentials.
Click the below link to do a “Factory Reset”
http://arris.force.com/consumers/articles/General_FAQs/SBG8300-Factory-Reset
Also, check the LED light status of sbg8300:
http://arris.force.com/consumers/articles/General_FAQs/SBG8300-LED-Light-Status
