how do I check for firmware updates on sbg8300 ?
  • October 15, 2025
  • 195 views
is it possible to get a firmware update for this modem?
DOCSIS standards dictate that the service provider must distribute firmware updates to cable modem devices.  The end-user cannot simply install an update like most other network-enabled devices.
ARRIS develops the software update and makes it available to service providers.  The service providers qualify, test, and distribute the software update to devices on their network.  ARRIS has limited control or visibility on distribution by the service providers.
  • October 17, 2025
So its a no. Modems and modem/router combo devices aren’t user updateable.
Is there something you think you need a firmware update to fix?
