Keep losing my 5G module
  • August 2, 2022
  • 8 replies
  • 194 views
I find I keep losing my 5G module forcing me to restart my router as often as twice per week, is it my unit or are there others with the same issue?
Change them off auto and select an actual channel. For the 5ghz go with 36-44 or 149-165.
Avoid the DFS channels as you might be near somewhere that broadcasts on them (they’re required to switch off those channels if it detects a signal)
  • August 3, 2022
What device do you have?
When you’re having issues with the 5g, do all devices have issues or just one?
What 5ghz wifi channel are you broadcasting on?
  • August 4, 2022
I have the SBG8300
The issue I’m referring is when all devices are affected, if it’s only one device I will restart the device, when it’s multiple devices I restart the router, 2.4 module is rarely affected.
“ What 5ghz wifi channel are you broadcasting on? “
Primary and guest, same with the 2.4 module, primary and guest.
  • August 4, 2022
I mean like channels 36-44? 149-165?
What 5ghz channels are you on?
Does changing the 5ghz channel help?
  • August 4, 2022
Looking through my router settings, looks like the channel selection is set to automatic on both the 2.4 and 5G,  I see no channel info. This is the way it was when my ISP set me up.
  • August 4, 2022
  • August 4, 2022
Thanks for the info, I’ve made the channel change, I’ll give it a few days and be back with an update!
  • August 12, 2022
Update, so far so good, tried channel 149 to begin with and lost my 5G twice in a 36 hour period, decided to drop to channel 36 and work my way up one channel at a time until I have some positive results, channel 36 has been stable for about 4 days now, hoping that keeps up. Thanks for the responses!
  • August 12, 2022
Glad to hear its staying stable!
