lag spikes SBG8300
  • October 17, 2023
  • 109 views
Every time I go to play I have packet bust and packet loss that makes me rubberband while play warzone please help
The logs are Values read by technicians from the internet provider end, since the logs are what the coaxial cable transmits and the log screen on the router is the translator so can be easily read by them, the coaxial cable is owned by the Internet service provider.
If your Event Log is reporting a high volume of errors, this would indicate a potential CMTS signal issue. To troubleshoot these errors, we would like to note the current signal levels being used by your (SBG8300).
The above signal level of Downstream and upstream have been verified.
There are some important things that should be within a specific range in order for the internet to work properly.
First, the SNR should be above 33 on all of them. The downstream power should always be between -15 and +15. The closer to 0 the better connection. Finally, your upstream power should always be between +45 and +51
The upstream values are not in accepted level so this needs to be checked again after reconfiguring the modem
so please do hard reset on the modem then check again the signal levels.
  • October 21, 2023
That’s after the reset
  • October 21, 2023
Looks like I’m not getting enough upstream?
Usually the upstream channels power level should be greater than 45 dbmv.
Since its not in a range, I suggested you to contact internet service provider to adjust the power level for the upstream channels in range.
