modem wont work
  • January 16, 2026
  • 40 views
ISP did update last night. Modem green light blinks slow than fast then turns blue. How to fix?
We recommend checking your current subscribed internet speed to help determine whether the issue is related to device compatibility.
Please refer to the link below, where you can find the approved speed tiers supported under Spectrum.
https://www.spectrum.net/support/internet/compliant-modems-spectrum-network
Based on your product model SBG8300, could you please confirm your subscribed internet speed plan and the name of your internet service provider?
  • January 16, 2026
I do not know the speed. Spectrum.
